Home > Forums > CD-adapco
Boundary baffle error 258
Old   November 17, 2006, 15:48
Default Boundary baffle error 258
Nalleli
Hi there,
I'm using a baffle boundary as a wall in a small region of my simulation. The flow is inviscid, therefore I have applied slip condition on both sides of the baffle. But when i run my simulation, I can see near the wall effects of viscousity, which were not present when I was using a normal wall boundary, can anyone tell me what is happening.
The second problem I have is, I performed an adaptive grid refinement to capture my regions of interest. When I try to create the geometry file the following message appears:
*ERROR - FACE DEFINED BY VERTICES [1029,1030,2141,2140]
IS ONLY DEFINED BY BOUNDARIES OR BAFFLES BOUNDARY
355, BAFFLE 3782
*ERROR - THE BAFFLE BETWEEN CELLS -1 AND -1
hAS A BAFFLE BOUNDARY DEFAULTED TO REGION 0.
THIS IS NOT ALLOWED WHEN RADIATION IS TURNED ON
IN EITHER CELL.
I've already merged cells and vertices, tried coupling, also, I've checked if the radiation was turned on the baffle boundary conditions and on my general model. I do not know what else to do.
Could someone help me?
Thank you before hand.
Nalleli
Old   November 18, 2006, 16:33
Default Re: Boundary baffle error 258
frodo
do you have baffle shells in there?
Old   November 19, 2006, 14:14
Nalleli
Yes, I have baffles shells in that region. And have specified them as baffle boundaries.
Thread Tools
Trackbacks are On
Boundary conditon of a baffle in the MRF region bono FLUENT 1 February 26, 2006 05:07
hot porous baffle azmir CD-adapco 0 February 9, 2006 20:25
baffle boundary sankar CD-adapco 3 March 16, 2005 04:54
Subroutine and Baffle yong CD-adapco 0 October 28, 2004 08:45
baffle in use guang ai CD-adapco 3 November 10, 2003 05:51
