connection refused problem
Old   November 23, 2006, 15:53
Default connection refused problem
RX
When I run the job with moving mesh method, the computor told me. Could not bind to local port 6543 Address already in use ruixu: Connection refused
At first I thought it was my problem. I tried the tutorial 11, the same problem happened.
Is there any one who can help me?
Many Thanks! ************************************************** ***** ************************************************** ***** To locate the problem easily, I list the prompt words below when I run the job. ************************************************** ***** ************************************************** ***** PNP: **WARNING** STAR case directory appears to be copy of a running case on "mace-r-ruixu" with process-ID "20537". PNP: Initialized [2006-11-23-12:52:17] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "mace-r-ruixu,1" resource (1 process). PNP: Overload STAR master processor with external moving mesh code. PNP: Assigned "mace-r-ruixu,1" to STAR solver (1 process). PNP: Assigned "mace-r-ruixu,1" to external moving mesh code (1 process). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Copyright Run Time Portions of this program include material copyrighted (C) by Absoft Corporation 1988-2006 PNP: Starting TRACKER task on "mace-r-ruixu" for monitoring host and process failures. PNP: Starting MVMESHD task on "mace-r-ruixu" for spawning external moving mesh code. PNP: Spawning STAR process on single node. *** Using FLEXlm licensing *** License version 09-oct-2004 Checking license file: 1999@cfdclust.me.umist.ac.uk Checking license file: /usr/local/star/star_version4.0/license/license.dat Unable to list features for license file /usr/local/star/star_version4.0/license/license.dat. 1 copies of starsuite checked out from 1999@cfdclust.me.umist.ac.uk Feature starsuite expires in 219 days RUNNING CASENAME valve
STAR 4.00.011 [Genesis_035]: linux64_2.4-absoft_9.0a-glibc_2.2.5-dso
*** Reading geometry ***
Sorting cells
Sorting faces *** Read complete ***
*** CLIENT SERVER PROTOCOL
EXTERNAL MOVING MESH CODE is running on host: mace-r-ruixu
In the directory: /home/rui/Documents/star_cd/EWBODBE/22-11-06
*** Socket based EXTERNAL MOVING MESH CODE communication
*** LOOK_AHEAD FLAG SET ***
EXTERNAL MOVING MESH CODE WILL EXECUTE ADVANCE MESH MOTION (FOR NEXT TIME STEP)
LIVCLL AND NEWXYZ SUBROUTINES WILL NOT BE AVAILABLE
Could not bind to local port 6543 Address already in use mace-r-ruixu: Connection refused
Old   November 23, 2006, 16:02
Default Re: connection refused problem
Richie Cunningham
try with the option -nooverload or contact support...
Old   November 23, 2006, 16:09
RX
Sorry, where I can do that?
Old   November 24, 2006, 16:57
notdiscl
type 'star -help' in your shell...
FoamSystemCheck fails ssh to current host is refused miles OpenFOAM Installation 3 March 17, 2008 02:36
SolidWorks Connection andrew mettler hayes FLUENT 3 August 8, 2007 14:48
fluent background connection refused Reginaldo Cotto FLUENT 3 June 17, 2007 07:30
connection with a server greg FLUENT 4 August 16, 2006 01:26
Interface connection Gab CFX 6 April 27, 2005 10:43
