Usage of Star-CD in analysis of Wind Turbine
Old   June 14, 2006, 03:49
Default Usage of Star-CD in analysis of Wind Turbine
Manabendra M. De
Hello all,
Myself, i am a student of turbomachine and i am doing aerodynamic analysis of stall regulated 2 bladed wind turbine. I have used the basic BEMT methodology as well as a commercial software Bladed for analysis. i intend to use a CFD package for the same.
So if any one of you can give me a feedback so as to how can i proceed with the highly unsteady and turbulent environment of 3D analysis of wind turbine, it will be helpful.
Do sent your feedback at manabendra_de@rediffmail.com
thanx and regards
manabendra de
Old   June 27, 2006, 04:35
Default Re: Usage of Star-CD in analysis of Wind Turbine
ismail empliouk
HELLO! I would like to send me a software demo.SOFTWARE DEMO - SOFTWARE CFD FOR TURBO MACHINES.Thank you
Old   August 28, 2006, 17:07
wihadi
HELLO! I would like to send me a software demo.SOFTWARE DEMO - SOFTWARE CFD FOR TURBO MACHINES. Thank you
Old   September 25, 2006, 15:02
He
ask for a demo from your local agent with starccm+ (not star-cd)
Old   November 18, 2006, 07:29
HAILITE
Grid connect WIND ENERGY System's output is connected to your ring main via a Grid-tie inverter which produces 230 volts AC @ 50Hz (240 volts AC @ 60Hz )synchronized to the grid. When the turbine's power is not required in the house, the surplus flows back out to the local grid. You will need an export electricity meter and tariff agreement with the power supplier if the value of your exported energy is to be credited. That grid-tied inverters are designed to be switched off in the event of power failure.
This is where Hailite Windpower comes in.
www.windchina.cn
Old   January 6, 2007, 23:42
kencewindpower
Kence Windpower Co. is a leading company in wind energy development and application. We have an advanced expert consultant team in wind energy, and do well in wind turbine subsequence development and perfecting technology. Our main products are wind turbines ranged from 200w to 15kw. Wind turbine system is an ideal power supply for separate house, island, observatory, sentry, signal transformation station, communities and other places with good wind resource. Our wind turbine is beautiful, little noises and safe. Wind turbine uses directly drive permanent magnet generator which is made of strong magnet; its overloading capacity can reach 2 times than rated. Wind turbine can start up with breeze. Blade is designed on base of wind tunnel testing and is made in a similar way to airfoil. There are two ways to limit the rotor speed automatically to protect wind generator: yawing and electromagnetic braking. A patent tilt-up tower makes wind turbine installation and maintenance easier. Bring brightness to every corner in the world!
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
analysis of wind turbine blades sharuk Main CFD Forum 7 December 9, 2014 18:59
Vertical axis wind turbine CFD Analysis Akhilesh FLUENT 4 April 13, 2012 16:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
wind turbine Jackie FLUENT 3 June 28, 2005 03:20
