refinement
Hi to everybody,
I have a problem with the refinement of my mesh. When I try to refine my 3D mesh (546000 cells) in X and Y directions only, an error panel appears and tell me to arise the maxcel and maxvrt memory. When I do this procedure another panel appears and warn me that I can not arise maxsc2 more than a default number. Can you think what maybe is the problem? Thank you in advance George |
Re: refinement
Go through prosize and set the memory parameters up front to what you need before starting up prostar. Its almost always more efficient to get all the memory first than to get some to start and more later. If this doesn't work then perhaps you need to be on a 64bit system (if you are not already).
