-   CD-adapco (
-   -   torque converter (
ramesh January 9, 2007 07:05
torque converter
Hai cfd experts
Presently am doing torque converter cfd analysis using starcd.I am confused with the interface boundaries between stator-turbine,turbine-pump,and turbine-stator.What is the value to be specified there?Can anyone help me in solving this.
Thanks and Regards Ramesh
Thomas January 9, 2007 07:56
Re: torque converter
depends on your method: Multiple reference frame or sliding mesh. first one is steady state mehod, second one is transient.
ramesh January 9, 2007 08:22
Thanks Thomas.Am doing steady state analysis.I know only the mass flow entering the torque converter and the pressure at the entry and exit of torque converter.But asper starcd manual it says that we need to define pressure boundary at the upstream and downstream of pump,inlet boundary at the upstream of turbine and pressure boundary at the downstream of turbine,inlet in the upstream of stator and -ve inlet in the downstream of stator.Then only we can group the interface boundaries to use explicit approach.What values should I specify in these regions? Please help me.
Regards Ramesh
Paul January 9, 2007 10:41
you should do this in starccm+ with MRF and interfaces (for example mixing planes+no reflection option) or rigid body motions. An example is on the on-line help.
For rotating geometry: star-ccm+
For combustion + droplets: star-cd
ramesh January 10, 2007 02:56
Thanks Paul.But I have created my grids and boundaries using ES-TURBO.Please can u help me in sorting out this problem within starcd.I want to use only starcd.
Regards Ramesh
ramesh January 10, 2007 03:00
Hi paul
Can u please give me the path of that online help.
Regards Ramesh
Actually... January 10, 2007 16:00
you can export your mesh from prostar (ngeom command or save the .ccm file in prostar v4) then import it into star-cm+
I was told es-turbo will be transfered to star-mm+ so it might be a good idea to get used to it :)
ramesh January 12, 2007 07:38
Is there nobody to answer my query about torque converter???
Plz help me.
ask the account manager January 14, 2007 12:32
You must ask your account manager for help, manauals and cd-rom. That is his job and every users is entitled to it.
Steve January 15, 2007 06:02
From time to time (typically university) people upload the help to their external web sites. This is almost certainly contrary to their licence agreement.
ramesh January 18, 2007 06:05
Hi everybody
What is the solution for my query about torque converter?
Thanks a lot in Advance.
Subrat Shrivastava March 15, 2007 09:02
res sir i am the student of automobile engineering at oist bhopal i need a book called THE TORQUE CONVERTER- P M HELDT is it available in india???? i'll be thankful if you please respond
thank you sir!
