Gambit to Star-CD
Old   January 15, 2007, 09:45
Default Gambit to Star-CD
rayy
Hi all,
I'm a new user. Is it possible to do the meshing in Gambit and then export it to Star-CD. How can i do that? please help.
Thanks.
Old   January 15, 2007, 23:44
Default Re: Gambit to Star-CD
kia
in gambit .. use solver - generic/polyflow
export mesh in *.neu format
in command window use
gambit,filename.neu
all the best
Old   January 16, 2007, 05:10
Kasper Skriver
a hint: clear the cell types in star-cd before importing. Leave a fluid type.
another expensive hint: if you want baffles then simply don't connect the faces between volumes where the baffles are supposed to be. Star-CD will see this as a wall and not merge the vertices automatically. You can also set a boundary face in Gambit but it will only give you a boundary in star-cd and not a baffle.
Old   January 16, 2007, 09:02
rayy
Thanks a lot for your hints, Kasper. You too Kia.
How to convert model from Gambit to Star CD ? Jimmy Siemens 4 September 16, 2008 10:07
Errors importing Gambit .neu files to Star v3.15 Cb Siemens 1 November 29, 2004 12:39
about Gambit 2.04 and STAR-CD Jack FLUENT 0 June 24, 2003 01:19
STAR CD with GAMBIT mesh? Jake Nikolic Siemens 9 July 8, 2001 10:02
How to import the Gambit file in star cd 3.05 NT Sangwon Kim Siemens 1 February 16, 2001 08:41
