Couple error
I have just run the analysis and it has come up with the following error:
CHECK ALL COUPLES A NEW CPSET WILL BE FORMED FROM ALL FAILED COUPLES **ERROR - SLAVE CELL 7425 FACE 5 OF COUPLE 111 IS A MASTER IN COUPLE 69 **ERROR - MASTER CELL 9285 FACE 5 OF COUPLE 112 IS A SLAVE IN COUPLE 69 **SUMMARY OF CORRECTLY MATCHED AREAS** TOTAL MASTER FACE AREA = 3.4938580 TOTAL SLAVE FACE AREA = 3.4995410 TOTAL AREA OF OVERLAP = 3.4892430 COUPLE CHECK COMPLETED. 2 ERRORS FOUND. NUMBER OF COUPLES PLACED IN COUPLE SET = 3 Can anyone tell me how to resolve this please? Thanks Regards |
Re: Couple error
Put couples check, and keep the option of create failed couples set on. After getting the couple error, try for couple merge. Again re-check
Most likely it will work. such messages come with multiple couples assigned to one or more cells face. |
Re: Couple error
When I do that one of the errors disappear, but one still remains:
cpmerge,all BEGINNING SEARCH FOR DUPLICATED COUPLES **NOTE - COUPLES 112 AND 69 BOTH HAVE CELLS: 9285 7425 COUPLE 112 WILL BE DELETED 1 DUPLICATE COUPLES FOUND CHECK COMPLETED MESH*> cpcheck,0.01,all,,,,0.05,nofix CHECK ALL COUPLES **ERROR - SLAVE CELL 7425 FACE 5 OF COUPLE 111 IS A MASTER IN COUPLE 69 **SUMMARY OF CORRECTLY MATCHED AREAS** TOTAL MASTER FACE AREA = 3.4938580 TOTAL SLAVE FACE AREA = 3.4995410 TOTAL AREA OF OVERLAP = 3.4892430 COUPLE CHECK COMPLETED. 1 ERRORS FOUND. And I can't seem to get rid of this one, please help. Thanks Regards |
Re: Couple error
If one problem is still there after couple merging. Means some local coupling problem is there.
Locally you should see the corresponding cells/coupling faces, keeping in mind the coupling rules. To start with, after checking for couples, delete the 1 couple which is giving problem and check for cracks locally. |
