Home > Forums > CD-adapco
Using LES
Old   January 24, 2007, 06:20
Default Using LES
Mohammad
I've one question about using LES-Smagorinsky turbulence model.
I wonder if I have to switch off the Turb. KE equation from the equation status found in: Analysis control => Solution controls => Equation behaviour => Primary Variables?
I've tried both having it switch on and off and in both cases the TKEmax found in field data in the .info file seems to vary at every time step hence the Turb KE equation is however solved.
Are there any recommended reading about this and thanks in advance.
/Mohammad
Thread Tools
Trackbacks are On
