January 27, 2007, 19:43 |
xy data from graph plot to excel
Hi
I am trying to check whether my model is grid independent. I need to compare the velocity at a particular location in different star cd models with different mesh densities. 1. I tried to specify the coordinates and get the plot along the line joining those points. It returns an empty plot though. Is there a more accurate way to do that? How? 2. I want to know how I can extract xy data from a graph plot (field data) in Star CD to an excel sheet. Regards Radhika Gundavelli |
January 29, 2007, 02:40 |
Re: xy data from graph plot to excel
Well you can allways try to use sensors at vertices you specify.
You can then scan values (e.i. x y z, u v w, p...). You can also save to a file, for instance *.grf that can be processed in Excel.. Try the help function in star. "help sens" "help gload" "help gval" "help sdat" "help close" |
January 29, 2007, 19:01 |
Hi..
I tried the sdata command, but the corresponding .grf file is empty. I see the data in the registers when I say post registers from lists in the main menu. sdata, <filename.grf>, 6, 1, 1, user Thats the command I typed in. Is there something wrong wih that? Regards Radhika Gundavelli |
January 29, 2007, 19:42 |
Thanks ...I got the .grf file
January 30, 2007, 18:54 |
I am still not able to do the second part i.e. extract xy data from a graph plot.
What I am doing right now is... 1. In the Star Guide: Extract/graph data / Field data data along a line line defined by endpoints cursor select two vertices 2. then I load SV in reg 4 3. Distance along a line 4. Create graph...to screen This displays the graph on the screen. I need x y data of this graph. I tried to say create graph ..to file ...but that creates a filename.plot file. which does not seem to be compatible with excel. Thanks in advance! |
February 23, 2007, 07:23 |
When you have managed to get the graph in star cd, you can use SDATA to print the registers to text files. those you can than import into excel.
How to Plot Graph in Fluent ? | Jane | FLUENT | 30 | September 14, 2017 02:32 |
how to use tecplot to plot 3D graph? | sam | CFX | 1 | April 30, 2008 21:42 |
How to plot different model's graph on a graph? | echo | Siemens | 1 | April 28, 2006 03:54 |
how 2 plot result data from VR-Viewer in 2 excel | anjani dubey | Phoenics | 3 | January 6, 2006 06:19 |
graph plot | anindya | Main CFD Forum | 2 | September 17, 2003 12:00 |
