How to find the coordinates of center of pressure
Old   February 1, 2007, 10:37
Default How to find the coordinates of center of pressure
Alexey
Hello. I have some problems with determination of coordinates of center of pressure in the conical model which is moving in the air flow with angle of attack equal to 0 degrees. From the beginning I have several models. The value of velocity is constant in these models and the angle of attack changes from 5 up to 0 degrees. I calculated the center of pressure in cases with non-zero angle of attack by the following method: Z= Sum(Moments)/Sum(SFTX) i.e. the sum of the Moments in every cells on the models surface was divided on the sum of the Total force in these cells in corresponding direction.
But now I don't have the normal component of the Total force, therefore I can't calculate the Moment.
Only one idea is observed: create a charts Z(angel) and continue they up to the 0 degree. But I can't explain this method. So I have two questions: 1. Was I right when I calculated the coordinates of the center of pressure in the cases with angle of attack NOT equal to 0 by described way. 2. How can I find the center of pressure in the case when angle of pressure is equal to 0.
Best regards, Alexey.
how to find center of press. loc. Xcp of 3d body? taimoor FLUENT 1 February 21, 2009 10:06
FIND center of vortex of steam function SARA FLUENT 0 November 1, 2007 12:20
Center coordinates of all the cells in a cellset lizhihua Siemens 0 August 21, 2006 03:59
?? How to get cell center coordinates? erica FLUENT 0 May 11, 2005 22:02
Getting cell center coordinates in Star-CD 3.22 Vitmalin Siemens 1 November 25, 2004 22:24
