Home > Forums > CD-adapco
Model conversion between codes
Old   February 8, 2007, 06:37
Default Model conversion between codes
Ale
can anyone give some information about how complex could be to convert an existing model from a code to another (let's say, from StarCD to Fluent or viceversa)?
Has anybody any experience on this?
Thanks a lot,
Ale
Old   February 8, 2007, 11:46
Default Re: Model conversion between codes
Pauli
It depends upon what you mean by conversion.
If you just want the grid (nodes & elements), it's not too hard. Most analysist codes support import/export using NASTRAN format. The caveat here is StarCD polyhedral cells are not supported. But then again, polyhedral cells aren't supported in most (all?) other analysist codes.
If you want boundary conditions, material properties, solver parameters, you will need a code-to-code specific translator. Check the import & export sections of the respective codes & try to find something common to both.
Thread Tools
Trackbacks are On
Model conversion from StarCD to Fluent Ale FLUENT 0 September 20, 2007 07:43
Model conversion between codes Ale FLUENT 0 February 8, 2007 06:37
how to model gas to particle conversion in CFX thandavan CFX 3 June 19, 2006 10:13
how to model gas to particle conversion thandavan CFX 0 June 14, 2006 05:28
conversion between CFD codes Roel Main CFD Forum 1 January 7, 2002 12:40
