February 13, 2007, 05:50 |
segmentation fault
Any new ideas how to fix segmentation fault problem for Windows XP?
I am using STAR-CD 3.26 and trying to do Tutorial 11.1 for moving mesh. When I try to specify sliding interface for mesh it always gives segmentation fault problem. I work on Windows XP, Service Pack 2. Does anyone know how to solve this problem? Regards Usker |
February 15, 2007, 14:14 |
Re: segmentation fault
Usually a segmentation fault is a memory problem of some sort. Check to assure that you have enough RAM for the problem and maybe check out prosize to assure it is set properly. Tom
February 15, 2007, 19:23 |
Thank you Tom for your reply. I use Pentium 4CPU 3GHz, RAM 3GB, Windows XP service pack 2 and I also tried service pack 3. It gives the same problem. Do you think it is enough memory? How do you think if I use Windows 2000 would it help?
Thank you again for replying Usker |
February 16, 2007, 00:22 |
SUSE 9.3 should be fine.
February 19, 2007, 05:55 |
r u using 32bit r 64 bit machine and if ur using 32bit - redhat linux 9 or enterprise version problem with kernel.
add default LD_ASSUME_KERNEL=2.4.19 line in harware.ini ($stardir/etc/hardware.ini) all the best |
March 5, 2007, 23:14 |
If you are sure that your hardware memory can support your model, then try to get the latest patch from STAR-CD support.
[Technical] Segmentation fault in map | msg30 | OpenFOAM Meshing & Mesh Conversion | 6 | March 27, 2008 10:49 |
Segmentation fault | billy | OpenFOAM Installation | 20 | April 23, 2007 22:57 |
segmentation fault | natesan | Siemens | 4 | January 12, 2004 08:51 |
Segmentation fault | Veebs | Siemens | 3 | June 4, 2002 22:17 |
Segmentation fault | Jose Sanchez | Siemens | 1 | December 16, 2001 08:13 |
