-   CD-adapco (
-   -   Line contour plot in black (
Radhika March 12, 2007 01:23
I created line contour plots with the default grey scale palette. Each contour is identified by a line whose intensity is in some way proportional to the magnitude and an alphabet.
I'd like to know if the contour lines i.e. A,B, C etc.. can all be converted to black color as they would show better in copies. In other words, identify the contours using the alphabets only.
xdm March 12, 2007 04:58
Re: Line contour plot in black
This is a thermofluidynamic code forum!
Anton Lyaskin March 12, 2007 08:24
Well, disregarding the fact that it is a thermofluidynamic code forum, the answer is yes, it's possible :)
Use the color tool to redefine post colors (from 21 to 34 or 40) to pure black
Babu March 22, 2007 07:44
Hi, Anton Layaskin,
I was also searching for the same. Eager to know. Can you please elloborate on this...I want to differentiate each color from the neighbouring color with a black line and say the incremental step for easy reading of results. Can I also get the same display lines on contour fringes too?
Your help is very much appreciated.
Thanks Babu
