Star CCM - Problem with image hardcopy quality
I am having a problem with the appearance of my hardcopy images. The saved output image quality is black and white, with a lot of vertical lines gray lines. NOTE: The view within Star CCM is perfect and this problem has only occured since the update.
Any help will be much appreciated. |
Re: Star CCM - Problem with image hardcopy quality
never seen that myself, which version and os are you using?
Try to set your surface lighting to [1.0, 0.0, 0.0, 1.0] for contours for example.
This approach helped for me when I had irregularities between screen view and actual hardcopy. BR Kasper Skriver |
