problem in generating subsurface in proam??
Old   March 13, 2007, 17:42
Default problem in generating subsurface in proam??
Ramesh
Hi all, i am a novice star cd user.Using proam i was trying to mesh my model ie)a straight air duct.I followed the steps mentioned in the tutorials and when i try to generate sub surface i see one of the wall surface touching the subsurface completely(looks like its merged together)whereas in the tutorial it is mentioned the surfaces should not be n contact.(the inlet,outlet and the other end of the wall surface has no contact with the subsurface).can anybody help??
thanks, ramesh
Old   March 14, 2007, 09:03
Default Re: problem in generating subsurface in proam??
sidd
Look for variable thickness option in subsurface generation.
Old   March 14, 2007, 12:54
Ramesh
Thanks Sidd, will try that.
Old   March 14, 2007, 15:47
Ben
It could also point to a problem in the original surface, if it is poor quality the subsurfacer may not be able to offset the shells correctly and will reduce the subsurface to zero
subsurface problem raffap Siemens 0 May 4, 2007 11:39
problem in genrating subsurface with proam Mir Siemens 0 January 24, 2005 08:49
proam -subsurface meshing tak Siemens 3 December 30, 2004 10:23
Problem in generating geometry gaurav FLUENT 3 October 18, 2003 00:38
Problem with proam Mir Siemens 2 March 26, 2002 04:54
