-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Problems when I mesh my engine model. (http://www.cfd-online.com/Forums/cd-adapco/55940-problems-when-i-mesh-my-engine-model.html)
deisler March 22, 2007 02:55
I drew an engine model in UG and import it to Pro-amm. I use the MeshWizards to mesh it. But every step I encounter an error:error deleting "./tmp/TMP.set":object is too large for operation.
Finally I failed in subsurface creating.
Why??PlZ any1 help me? Thank you!
usker March 22, 2007 03:37
Re: Problems when I mesh my engine model.
I would recommend you make 3D model using any solid modeling software (UG, Pro-E, Solidworks etc.) as you have already done, then you save that model as IGES file, then you open that IGES model in pro-STAR/surf. In pro-STAR/surf you generate a surface for your model, then save it as *.cel. Then you go to pro-amm, activate Mesh Wizard open your *.cel model and follow the steps.
Regards
deisler March 22, 2007 21:45
Thank you!Problems have been solved. But when I use meshwizard to creat subsurface,It always deletes some surfaces(to give my model a BIG HOLE ),and when I finish all steps,the hole is there ..... cset all,cplot It seems that my model has been given a BIG HOLE... So why? Usker,cud u help me?
Regards
usker March 22, 2007 22:58
OK, first when you create surface in pro/surf you need to repare it. Make sure you join all the lines so that your surface is continious without any missing cells. Then in pro/amm in the Mesh Wizard in the step 2 (Prepare Surface) there is an option "Close Free Edges and Fill Holes". You select that. Then try again. I would recommend you get User Guide and Tutorial (pro-STAR with auto mesh generation). You can find these User Guide and Tutorials in your Star-CD directory folder. They have very extensive information on mesh generation.
Regards
