What should I do to accelerate the solution
Old   March 22, 2007, 05:33
Default What should I do to accelerate the solution
Ivan
I have a very long elbow tube. Convergence is too slow(by mass eq). How could I accelerate the convergence.
StarCD 3.26
Regards!
Old   March 22, 2007, 05:54
Default Re: What should I do to accelerate the solution
Kasper Skriver
Maybe use the traditional approach: Starting of with a 1'st order solver scheme, then switch to 2'nd order later. Try to adjust the under relaxation factors to a lower level. It might help.
Convergence on mass is generally slow.
Old   March 22, 2007, 07:08
Balduin Bankerotti
You might have to create a more suitable mesh.
Old   March 22, 2007, 08:13
allan
try amg solver
Old   March 23, 2007, 08:18
sidd
If you are using second order differencing schemes, convergence will be slower in the beginning. But after reaching a stable stage, low relaxation factor doesn't help much and can be increased upto some level. But upto what level it is safe, i can't say as it depends very much on mesh, geometry and differencing scheme.
you can dynamically change the relaxation factor after a stable residual is reached.
how to accelerate fluid in bluff body case? Rui Main CFD Forum 7 March 5, 2009 10:45
Do you know of any tweaks of the solver parameters to accelerate solution convergence sek OpenFOAM Running, Solving & CFD 0 September 15, 2006 13:45
Accelerate the assembling of 3D convection matrix Isabel Main CFD Forum 6 December 22, 2005 12:22
Accelerate convergence in coupled solver Balaji FLUENT 3 June 23, 2005 18:16
How to accelerate a time-dependent algorithm to steady-state? Matthew Cordery Main CFD Forum 2 October 19, 1998 23:32
