Home > Forums > CD-adapco
Centrifugal Compressor BC
Old   March 28, 2007, 15:20
Default Centrifugal Compressor BC
Hello, I`am simulating a Centrifugal Compressor Stage with StarCD 3.26.
I use the MRF implicit steady state approach with only one mesh passage region. The grid structure is
Upstream H-Block (UH)-> Blade O-Block (OB) -> Downstream H-Block (DH) with surrounding cyclic periodics.
UH and DH have spin index with zero rotation speed, OB a spin index with nonzero rotation speed.
Because am going to compare the calculation results with experimental data following BC must be applied:
Inlet: absolute Totalpressure, absolute Totaltemperature, velocity direction
Outlet: mean static Pressure
Until now I tried BC combination Inlet+Pressure (1), Pressure+Pressure (2) and Stagnation+Pressure (3) for Inlet and Outlet Region. Unfortunately the following problems/ questions occur:
- How to set known Total Inlet BC (1) ? - How to avoid disorientated flow field after initialisation with low inlet and high outlet static pressure (2) ?
- How to set up stagnation BC right (I received a somewhat error message: difference between static and total pressure is lower than zero with calculation breakup before first iteration ) (3) ?
Perhaps anybody is able to help me with the prescribed problems. Thanks Tobi.
Thread Tools
Trackbacks are On
Doing Centrifugal Compressor Simulation? Lee FLUENT 3 March 31, 2010 05:28
centrifugal compressor Marek CFX 6 December 17, 2008 12:25
Centrifugal compressor performance ihuin CFX 3 April 14, 2006 00:13
centrifugal compressor siva appanna Main CFD Forum 5 February 13, 2006 22:07
centrifugal compressor modelling Glufoureea FLUENT 1 October 16, 2005 04:28
