Home > Forums > CD-adapco
how can i consider 25 mikron aliminium layer?
Old   April 2, 2007, 09:43
Default how can i consider 25 mikron aliminium layer?
nari
Hi everybody.. I am using STAR-CCM+... and in our problem there is a covering layer (aluminium) with thikness 25 mikron. and i have to solve heat transfer here. How can i consider this layer? I am waiting for your response as soon as possible.. Thanks everybody..
Old   April 4, 2007, 17:47
Default Re: how can i consider 25 mikron aliminium layer?
Joan
If you are thinking about heat conduction in the aluminum, it can be tricky. If you only need the shielding capabilities of the aluminum, try a baffle with thermal resistance.
Old   April 5, 2007, 02:48
nari
Thanks Joan.. there is not only heat conduction, also we are thinking about radiation effects.. and radiation coefficients of this layer also important for this problem.. i will try to use baffle interface.. thanks a lot..
Thread Tools
Trackbacks are On
"Shear layer" vs. "mixing layer"- Difference mazadeh Main CFD Forum 5 April 10, 2009 10:17
"Shear layer" vs. "mixing layer"- Difference mazadeh FLUENT 2 April 18, 2008 14:46
boundary layer Fer FLUENT 5 November 24, 2005 11:37
boundary layer StarCD CD-adapco 0 July 4, 2004 21:05
two-layer K-Eps A.M.Memarzadegan Main CFD Forum 0 October 7, 2003 07:17
