April 12, 2007, 07:07 |
Multifluid flow
I am simulating a counter current heat exchanger. Two fluid flow in opposite direction and are separated by a wall of zero thickness. When i tried giving that wall as "wall or baffle" stard-cd is not accepting. So can anyone help me out
I am in position not able to give the thickness My problem is short is "two flow with wall in between and what BC to give " |
April 13, 2007, 05:25 |
Re: Multifluid flow
How is your current geometry?
Is the wall made of cells giving it a thickness, or does the two fluid regimes lie right next to each other?? You can only assign baffles to faces and not cells. Otherwise you need to create a solid part as cells between the to fluid regimes. I have not tried this before, but this is my intuition. Maybe some other has done this? \kasper |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 17:36 |
External Flow-compressible flow solver-lift/drag | Tom Brown | Main CFD Forum | 7 | December 29, 2000 14:41 |
