Home > Forums > CD-adapco
Problems on 64bit Installation
Old   April 17, 2007, 04:12
Default Problems on 64bit Installation
Dietmar Schmidt
Hello Anybody,
I am using STAR 3.150A.044 together with Absoft 64-bit Fortran 95 9.0 EP compiler on a SUSE 10 64bit system.
I get prostar running (setenv LD_ASSUME_KERNEL 2.4.1 is set in my configuration file). But when I start to run the analysis of a test problem I get an error message and the code stops:
/usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib64/libm.so when searching for -lm /usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib64/libm.a when searching for -lm /usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../x86_64-suse-linux/bin/ld: cannot find -lm collect2: ld returned 1 exit status link failed.
Has anyone any suggetion?
Thanks a lot
Dietmar
Old   April 17, 2007, 10:15
Default Re: Problems on 64bit Installation
Ben
Why are you using such an old version? If it is some sort of incompatibility with the OS you aren't going to be able to get much support on something so old....
Old   April 17, 2007, 11:28
Ben
Actually now I think about it I am not even sure there is a 64bit port of 3.150A (although I may be wrong) what does it say on the disk....
Old   April 18, 2007, 04:24
Dietmar Schmidt
Hallo Ben
thanks for your fast respond! We are using such an old version due to compatibility of a code written around/within StarCD. As the people said to me there are a lot changees for the newer versions of StarCD, which at the moment are not compatible to our code. There is also no disc as we downloaded everything online.
Thanks a lot
Dietmar
Old   April 18, 2007, 06:36
Ben
Where did you download from and what is the contents of the tarball?
Thread Tools
Trackbacks are On
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
Precompiled 64bit linux installation milkovp OpenFOAM Installation 5 May 15, 2008 04:57
Installation Problems honcho OpenFOAM Installation 0 January 14, 2008 11:48
Problems installing OpenFoam on a 64bit machine jango OpenFOAM Installation 1 June 4, 2007 14:53
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
