swirl ratio reduction
Old   April 27, 2007, 23:55
Default swirl ratio reduction
sijin james
can u tell what wil happen to the swirl ratio at the time of compression?? wil it reduce?? in analysis i m getting a high value of swirl but less at the time of injection.. how can i justify that??
thank u all..
Old   May 1, 2007, 18:20
Default Re: swirl ratio reduction
Andrea
but the reduction of swirl ration depend on the geometry of the combustion chamber, am I right? If you have a bowl on the piston the swirl ration increases during compression due to momentum conservation...
Old   May 1, 2007, 22:58
sijin james
thanks andrea.. so u r tellin swirl wil reduce in flat piston but increases in bowl geometries is it?
Old   May 10, 2007, 06:12
Andrea
yes, is it. In piston with bowl it increase during compression while in flat piston not because of the dissipation of energy...in pistons with bowl it's also present but it's the conservation of momentum that predominate (sorry for the language...didn't remember how to say the last word!)
Ask for help on Drag reduction lakeat OpenFOAM Running, Solving & CFD 1 February 9, 2008 16:59
Drag Reduction and CFD Daniel Main CFD Forum 3 January 20, 2008 10:32
Residuals reduction pieizquierdo (miguel) FLUENT 0 February 17, 2005 14:47
Induced Drag Reduction Erich Main CFD Forum 1 March 22, 1999 04:39
On the reduction of cpu time lee Main CFD Forum 4 March 7, 1999 22:02
