problem related to transiant analysis
Old   April 29, 2007, 09:18
Default problem related to transiant analysis
Sangamesh
I am using the STAR CD for cfd simulation. I am simulating the cryocooler ( Which is one of the type of refrigeration system). For this i have modeled the compressor( pistion movement like in combution problem )
For moving mesh I used the SUBROUTINE NEWXYZ for vertex movement. and macevent file.
For simulating the compressor i am USING TRANSIANT analysis.
RPM given- 3000
and iam using advance Transiant, in that i have Time Step in terms of crank angle
I had run the system for TIME STEP: 360 (one cycle(360 dgree) i.e. 1 compression strok and 1 expansion strok)
3600 (for 100 cycle)
72000 (for 200 cycle)and i got the solution
FOR EACH time increment of 1
BUT when i gave the TIME STEP=360000 (1000 cycle), it ran up to time step: 99999
My MAIN problem is how to give run for TIME STEP 360000.
Old   April 29, 2007, 13:07
Default Re: problem related to transiant analysis
Ben
99999 is the max timestep, you are just going to have to run it in 4 parts using restarts
Old   May 7, 2007, 05:08
Sangamesh
Thank you sir for giving reply
But in transiant analysis we can't give for analysis restart option according to me it is aplicable to only steady state.(as per given user gide )
If i am wrong can you tell me how to give it.
Thanking you.
Old   May 7, 2007, 05:09
Sangamesh
Thanking you.
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 29, 2008 15:33
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 10, 2008 10:09
How to give restart option for transiant analysis Sangamesh Siemens 3 May 21, 2007 04:24
problem related to mesh naveen CFX 3 March 25, 2006 09:47
cavitation related problem Kamran FLUENT 1 June 14, 2004 04:05
