Home > Forums > CD-adapco
Error after installation..
Old   May 1, 2007, 17:00
Default Error after installation..
Nari
Hi everybody.. I have installed STAR-CD 3.26 on Windows XP. after installation i try to run prostar and proam. license and all are ok. But after reading license, there were error as below: "Error attempting to open X display"
SCO XVision were installed too.. What i have to do also..??
Thanks for your responses already..
Old   May 2, 2007, 04:57
Default Re: Error after installation..
Scibor
Try to use Exceed instead of SCO X Vision!
Old   May 2, 2007, 06:22
Kasper Skriver
Make sure that SCO XVision runs.
I'm using Hummingbird Exceed.
Old   May 2, 2007, 09:49
TG
If you look at the installation manual, there are a small number of settings for SCO that you have to change manually. You need to set SCO to start up automatically whenever it senses a request for X services.
Old   May 3, 2007, 06:22
Nari
Hi.. thanks for your responses. i will try exceed too. also dear TG i apply what was said in installation manual. open x server, change some settings. but it hasnt done.. thanks again for all your soon responses...
Old   June 28, 2007, 14:02
Andrea
Hi, I've got your same problem for the past 3 month...now I've tried to Install a free program called Cygwin and lauch the dedicated x server inside that program that allows win applications to run on a virtual unix machine...and that works!!! I've tried to do something inside Pro-S and it seems to work well... I hope you'll enjoy it! You can download it at http://x.cygwin.com/ , be sure to download all the packets of the voice at the bottom of the install list...to use simply for launching the x server run c:\cygwin\usr\X11R6\bin\startxwin.bat simply from windows and then launch Pro-S as usual with or without the launch screen, or read http://www.physionet.org/physiotools/cygwin/#using-x . Bye!
Thread Tools
Trackbacks are On
OF15dev installation error velan OpenFOAM Installation 11 February 13, 2009 10:23
Help Error Installation of openfoam15dev loneboard OpenFOAM Installation 4 February 4, 2009 10:24
Installation error sukratu OpenFOAM Installation 6 September 16, 2007 22:46
Installation Error rafal OpenFOAM Installation 3 February 2, 2006 12:43
Fluent 6.2.16 installation with Error EOF tuks FLUENT 3 July 13, 2005 13:20
