-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   How to give restart option for transiant analysis (http://www.cfd-online.com/Forums/cd-adapco/56043-how-give-restart-option-transiant-analysis.html)
Sangamesh May 7, 2007 04:12
Thank you sir for giving reply
But in transiant analysis we can't give for analysis restart option according to me it is aplicable to only steady state.(as per given user gide )
If i am wrong can you tell me how to give it.
Thanking you.
Ben May 7, 2007 05:53
Re: How to give restart option for transiant analy
you can do a restart on transient same as on SS providing you have the pst file.
azmir May 10, 2007 20:45
Not that simple due to bugs. Sometimes even after setting it to read from restart file, it doesn't work properly. SO, instead I used the star -dp -restart command. And even this sometimes revealed irregularities for case of transient... depends on luck I suppose.
Sanjay May 21, 2007 03:24
As stated in the manual an initial field restart is not possible . However a standard restart is easily possible. If you get into errors in starting check whether you have applied the standard restart option before writing out the mdl file and problem file and then you need to restart the run.
