May 8, 2007, 02:50 |
heat source
Hello, I am trying to give a heat source input to a solid material. Since I need to determine the temperature distribution, the input for heat is Q (W/m3). Should i be using sorent.f ?? Comments will be appreciated. Thanks, Mac.
May 8, 2007, 05:42 |
Re: heat source
Yes you use sorent.f.
May 8, 2007, 06:25 |
Re: heat source
U can use sorent.f or tables also. Personally I think sorent works better and is easier to use. U only have to set S1P=...w/m3 and S2P=0 specifing witch type of cell this source is applied.
if(ictid.eq.33) then S1p=... S2p=0 elseif return end this is the way I use it let me know if it's work properly! |
May 9, 2007, 05:00 |
Re: heat source *NM*
May 9, 2007, 05:01 |
Re: heat source
thanks....had another question. How do we use tables for this ?? Just for my information please.
May 9, 2007, 05:36 |
Re: heat source
U can set a table defining s1p and s2p for an enthalpy source. Then U assign this table to a cell type in source panel. But I've just said you, I don't know if it works well.
May 9, 2007, 06:24 |
Re: heat source
Thank you so much. Appreciate your help.
June 13, 2007, 10:02 |
Re: heat source
Dear scibor,
For Fixed Temperature i can give, S1p=GREAT*T S2p=GREAT what should i do for Volumetric heat flux?, how do i do that? Thanks |
July 15, 2007, 01:50 |
Re: heat source
#9 |
Hi,nava I have the same problems with you. But I don't know why you set S1P=great*T and S2P=great. what is mean of the "great"? why should you time the "great" in S1P and S2P?
If you know the total heat (W), you can calculate the volume of the source cell (m3). Your Volumetric heat is total heat/ volume. |
Display Modes | |
Heat source UDF, please | Sasha | Fluent UDF and Scheme Programming | 4 | October 14, 2014 02:32 |
Heat source in vof?????? | asghari | FLUENT | 0 | August 13, 2006 10:07 |
Input heat source (heat/unit volume) in 2D | Polly | FLUENT | 2 | March 18, 2005 02:04 |
how to add a heat source | wanghong | FLUENT | 0 | January 17, 2005 08:03 |
Heat-Source | James | Siemens | 1 | July 17, 2002 10:33 |
