May 12, 2007, 23:27 |
small size cell problem(moving mesh)
Hi guys, i generated moving mesh for sliding vane pump, in order to change cell position i used filling. when i run the solver solution diverge after some iter. then i checked result velocity is a very hight in smallest size of mesh(0.001 mm) i think velocity difference in biggest cell(0.41mm) and smallest cell(0.001mm) is too big that's why solution is unstable. how can i decide smallest cell, please advise.
May 12, 2007, 23:45 |
Hi guys, i generated moving mesh for sliding vane pump, in order to change cell position i used filling. when i run the solver solution diverge after some iter. then i checked result velocity is a very high in smallest size of mesh(0.001 mm) i think velocity difference in biggest cell(0.41mm) and smallest cell(0.001mm) is too big that's why solution is unstable. how can i decide smallest cell, please advise.
Limit on maximum cell size to minimum cell size ratio | albcem | OpenFOAM Running, Solving & CFD | 2 | October 17, 2011 12:00 |
Gambit: mesh size to small??? | Ralf Schmidt | FLUENT | 1 | January 28, 2006 01:26 |
Mesh/Cell size | Jamcam | Main CFD Forum | 5 | July 12, 2004 08:43 |
A 2-different size mesh problem | Luc | FLUENT | 1 | January 10, 2003 16:13 |
Problem in TE model and cell size | Mir | Siemens | 2 | December 11, 2001 09:46 |
