(step) combustion reactions
Old   May 15, 2007, 04:44
Default (step) combustion reactions
gosia stein
hello all defining both step combustion reactions and complete combustion reaction in one step (of propane) i get a warning that left and right hand sides of reaction aren't equal; checking it by hand, using data from STAR_CD database i get values approximately equal to the RHS-values shown in the output window; have you ever faced something similar? what to do? thx in advance
Old   May 15, 2007, 19:11
Default Re: (step) combustion reactions
Pauli
Approximately equal to is not the same as exactly equal to. Prostar requires exactly equal to.
Check it again until you sort out why Prostar is doing what you ask instead of what you desire.
I've had this problem. So I feel your pain. Unfortunately it's been a while & I don't remember all the gory details. Is it something with how the base fluid is book kept?
This is a basic stoichiometry calculation. I'm a little confused when you say you used data from the StarCD database. What data?
Old   May 15, 2007, 20:52
usker
Please, send the reaction formula. After I see it I can tell you what is the problem.
Regards
Old   May 16, 2007, 09:49
gosia stein
thx a lot; i have already solved the problem; one of the data from database was wrong; regards
Multi step reations (80 reactions mechanism) simul Patrick Main CFD Forum 0 August 16, 2008 12:17
time step in unsteady combustion process FRANK LEE FLUENT 2 July 25, 2007 04:51
premixed combustion step? John FLUENT 0 August 12, 2004 22:03
MIX_FRAC-FUEL_2 in 2-step combustion Julie Polyakh Siemens 1 April 28, 2004 03:16
