May 15, 2007, 23:52 |
COUPLE ERROR
Dear guys,
i am fed up with couple errors.please help. It shows the error like this: ''MASTER FACE OF ... COUPLE IS SLAVE FACE IN .... COUPLE......." OUT OF 93000 COUPLES IT IS SHOWING FOR 400 COUPLES. hOW TO REMOVE THIS. tHANKS IN ADAVANCE |
May 16, 2007, 13:37 |
Re: COUPLE ERROR
Use the couple tool. First select check couples. On the check couple gui select yes for build new couple set and remove non overlapping couples. Click apply and enter "c" when it stops the first time. It will put all couple errors in a cpset so use delete couples to remove the errors. Run this check until you get no errors. Then use the check tool for connectivity and cracks. Unless there are other problems, this should fix it.
Tom |
May 16, 2007, 13:55 |
Re: COUPLE ERROR
Bump up the couple check tolerance â€" you just don't see the errors - pray to the CFD gods that the model still runs
Delete the offending couples â€" no more problems - just a few extra open faces blocking your flow Move to STAR 4 and/or CCM+ - no more couples. |
May 17, 2007, 05:19 |
Re: COUPLE ERROR
Your problem starts when your create couples - this error means that Prostar was picking master cells randomly from both sides of the interface. It will really, Really, REALLY help if you'll use different cell types (one type from one side of the interface, another type at the other side of the interface) and then use master-slave assignment on a cell type basis
Display Modes | |
To 'couple' or not to 'couple'...) | Freeman | FLUENT | 0 | March 5, 2009 11:29 |
Couple | c0384 | Siemens | 1 | December 6, 2007 15:00 |
Couple error | Yehia | Siemens | 3 | January 25, 2007 03:58 |
Couple information | raffap | Siemens | 2 | December 21, 2006 02:53 |
error 84 couple error | Tipakorn | Siemens | 6 | March 10, 2006 17:35 |
