July 3, 2007, 02:20 |
mixing of helium in air
Hello guys,
I am trying to simulate the mixing of helium in air.Helium is being injected from bottom at some velocity in a cylinder initially filled with air at atmospheric pressure.an outlet is provided at the top of cylinder. I am trying to match the results with some experimental data. USING- 1)KE standard model for turbulence 2)transport method of solution I am not getting good reults (conc. of helium)for half portion along the height from bottom. Does anybody is doing such type of problem. kindly forward your suggestions. |
Mass transfer of Heated Helium in Porous Silica | TheAlchemist | FLUENT | 0 | February 24, 2007 08:56 |
LES of helium jets | rajani | FLUENT | 0 | February 20, 2004 13:28 |
Large Eddy Simulation of helium jets | Rajani | FLUENT | 0 | February 19, 2004 12:25 |
Helium-Decomposition | chakri | Main CFD Forum | 1 | December 13, 2002 04:17 |
Sutherland's Law - Helium | Nashat Ahmad | Main CFD Forum | 5 | July 29, 2002 10:46 |
