scripting gridgen: why a connector is not saved??
Hi, I wrote a script with two loop:
for (j..){ for(i...){ gg::conBegin gg::segBegin -type 3D_LINE gg::segAddControlPt "$a $b $c" gg::segAddControlPt "$a $d $c" gg::segEnd set con(0,$j,$i) [gg::conEnd] }} at the first time when j=0, the connectors are saved but at the second one I've got an error message.. ERROR: connector not saved while executing "gg::conEnd" I looked for why there is that error but I didn't find out... Does someone know in which case a connector is not saved?? Thanks for your help A part of my script, if you need to have a look... set Largeur_ss_etran [expr {$Largeur - $Longueur_Etran}]; set dist_entre_brise_H [expr {$Largeur_ss_etran / [expr {$Nbre_Brise_H + 1}] }]; set dist_entre_brise_V [expr {$Largeur_ss_etran / [expr {$Nbre_Brise_V + 1}] }]; if {$Nbre_Brise_V > 0} { set BV 2 } else { set BV 0} set j_limit [expr {$Nbre_Brise_H + [expr {$Nbre_Brise_V + [expr {$Nbre_Brise_E + 2}]}]}]; set i_limit [expr {3+$BV}]; set jh 0; set jv 0; for {set j 0} {$j <= $j_limit} {incr j} { #Coordonnées selon l'axe x set bh [expr {$Longueur_Etran + [expr {$jh * $dist_entre_brise_H}]}]; set bv [expr {$Longueur_Etran + [expr {$jv * $dist_entre_brise_V}]}]; if {$bv == $bh} { set a $bh incr jh; incr jv; } else { if { $bh < $bv} { set a $bh; incr jh; } else { set a $bv; incr jv; }} set c $Demi_Hauteur; #Coordonnées selon l'axe y for {set i 0} {$i<= $i_limit} {incr i} { if {$Nbre_Brise_V != 0} { switch -glob -- $i { 0 {set b -$Profondeur} 1 {set b [expr {-$Profondeur+$Brise_V_y}]} 2 {set b $Largeur_Etran_2} 3 {set b $Largeur_Etran_1} 4 {set b [expr {$Profondeur-$Brise_V_y}]} } switch -glob -- $i { 0 {set d [expr {-$Profondeur+$Brise_V_y}]} 1 {set d $Largeur_Etran_2} 2 {set d $Largeur_Etran_1} 3 {set d [expr {$Profondeur-$Brise_V_y}]} 4 {set d $Profondeur} } } else { set b0; set d 1; } gg::conBegin gg::segBegin -type 3D_LINE gg::segAddControlPt "$a $b $c" gg::segAddControlPt "$a $d $c" gg::segEnd set con(0,$j,$i) [gg::conEnd] } } |
Re: scripting gridgen: why a connector is not save
I think this is best asked in the main forum as this is the STAR-CD one....
Tim,
The first thing that comes to mind is that the connector isn't saved because it duplicates one that already exists. Gridgen won't allow two connectors to be coincident. I briefly looked at your script and didn't see any other obvious source of the problem. But I didn't run the script since it was just a fragment. If this isn't the problem, contact Gridgen Tech Support at support@pointwise.com. |
