Not converging
Old   July 5, 2007, 16:08
Default Not converging
CPRL
Hi, I have a very simple model with just several inlets and one outlet. However, it doesn't converge when I run it. I used prostar to create the mesh. Can anyone please tell me what could be the problem? I used UD scheme. I checked everything before I run it and I didn't find any error. Thank you.
Old   July 5, 2007, 16:29
Default Re: Not converging
Adam
There could be many reasons. Without more information about your model its really hard to say.
Is UD appropriate for your flow? If your flow is highly dependent on downstream conditions try a different scheme like MARS
Have you selected the appropriate turbulence models?
How many iterations have you let it run?
Are the residuals oscillating, decreasing, or increasing?
Old   July 5, 2007, 17:03
Ben
define "not converging" better....it could be one of a load of things..if you are using an outlet, try a pressure boundary instead
Old   July 9, 2007, 13:06
CPRL
Thanks Adam and Ben. I think the problem is fixed now. I was using laminar model earlier. Now I swithched it to high reynolds # k-epsilon turbulence model since the Reynolds # in the simulation is high. It was oscillating earlier. Now it is converging after 10,000 iterations. Thank you.
DPM converging Problem Markus Alzon FLUENT 6 April 7, 2016 11:41
CFX CPU-Fan not Converging Danyal Mathews CFX 3 December 24, 2008 01:11
converging mehrdad FLUENT 0 November 18, 2007 00:45
Energy eqn is nt converging.......plz help? preethi FLUENT 3 March 30, 2006 23:17
Converging very slow Q FLUENT 0 March 16, 2006 03:48
