diesel spray combustion equivalence ratio
Old   July 8, 2007, 20:29
Default diesel spray combustion equivalence ratio
usker
Hello guys, Could you please suggest how to obtain equivalence ratio for diesel spray and combustion. Diesel fuel is sprayed into constant volume chamber with 900K temperature and high pressure air. I am calculating transient. Equivalence ratio is stoichiometric air-fuel ratio devided by actual air-fuel ratio. How to get equivalence ratio value over time. As I know it is possible to insert a formula and link it to scalars, then I just insert the stoichiometric air-fuel ratio value and actual air-fuel ratio, but how to define air for actual air-fuel ratio, because if I link it to scalars, in the output the program only gives oxygen and nitrogen, but how to define air?
Thanks a lot
Old   July 23, 2007, 17:59
Default Re: diesel spray combustion equivalence ratio
Andrea
Hi, I don't remember very well but if I'm right you've got scalars O2 and N2 defined in terms of mass [g or kg]...so if you want do define the air for your formula you need to express air in term of mass concentration of O2 and N2...is it right? Then it's just something like m_air=0.23*m_O2+0.77*m_N2
Old   July 24, 2007, 00:06
usker
Thank you very much, Andrea.
Old   August 9, 2007, 02:16
Default Re: Automobile Engineering
Arivumani
i want to all the details for automobile engineering notes and line diagrams....
Old   September 6, 2007, 01:42
Default i am doing diploma in mechanical engg
Deepika Garg
I Want all the notes of automobile engg. & diagram diploma level engg.plz reply fast.
Thanks& Regards Deepika Garg
Old   September 26, 2007, 04:31
Default Re: i am doing diploma in mechanical engg
sunil
i am doing diploma in mechanical engg (evening) in bangalore and i request you please give me root for 1st sem notes of applied science.
Old   October 25, 2007, 03:57
muthazhagan
i want to know about the course contents in automobile engineering subject.
Old   November 2, 2007, 14:37
amol sawant
i wanna all nots of for all sub of 3rd year yearly pattern course please help me
Old   December 5, 2007, 06:16
pradip maity
i am doing diploma in mechanical engg. on distance.
Old   December 5, 2007, 22:20
Default Re: i completed diploma in mechanical engg
SHARATH.R
Hai friends
Old   December 25, 2007, 12:44
Default diploma in mechanical engg
  #11
j tarun
d0nt think tath it was hard if u come after 10th then it will creat some problem but u will over come come by this .it has only the basic of 10th & 12th thats all if u further doubts then ask me...........
Old   January 6, 2008, 00:08
  #12
kia
wish u all the best for your higher studies
Old   March 1, 2008, 06:09
Default Re: diploma in mechanical engg
  #13
Manjinder Singh
i am doing diploma in machanical enginer.tool and degsin
Who can help me about equivalence ratio? Duan J Q Siemens 5 May 15, 2008 18:17
Multifuel Diesel Spray and Combustion usker Siemens 12 December 1, 2007 19:08
diesel spray and combustion with EGR usker Siemens 1 May 16, 2007 04:34
diesel engine spray and combustion usker Siemens 6 April 24, 2006 22:36
equivalence ratio Antony Siemens 1 November 18, 2005 10:59
