ERD file
I am modeling creeping flow. When I save the .erd file for mass flux, the value is so small that the file reads zero. Is there a way to change the resolution?
Re: ERD file
File *.erd contains only zero in mass column? Or registers equal zero when you upload *.erd? If the first is right i think, you can't do anything. If the second is right, you may try solve problem with scale factor. In that way starcd can use scaled number.
