scripting gridgen: why a connector is not saved??
Old   July 3, 2007, 12:30
Default scripting gridgen: why a connector is not saved??
Tim
Hi, I wrote a script with two loop:
for (j..){
for(i...){
gg::conBegin
gg::segBegin -type 3D_LINE
gg::segAddControlPt "$a $b $c"
gg::segAddControlPt "$a $d $c"
gg::segEnd
set con(0,$j,$i) [gg::conEnd]
at the first time when j=0, the connectors are saved but at the second one I've got an error message.. ERROR: connector not saved while executing "gg::conEnd"
I looked for why there is that error but I didn't find out...
Does someone know in which case a connector is not saved??
Thanks for your help
A part of my script, if you need to have a look...
set Largeur_ss_etran [expr {$Largeur - $Longueur_Etran}];
set dist_entre_brise_H [expr {$Largeur_ss_etran / [expr {$Nbre_Brise_H + 1}] }];
set dist_entre_brise_V [expr {$Largeur_ss_etran / [expr {$Nbre_Brise_V + 1}] }];
if {$Nbre_Brise_V > 0} { set BV 2
} else {
set BV 0}
set j_limit [expr {$Nbre_Brise_H + [expr {$Nbre_Brise_V + [expr {$Nbre_Brise_E + 2}]}]}];
set i_limit [expr {3+$BV}];
set jh 0;
set jv 0;
for {set j 0} {$j <= $j_limit} {incr j} {
#Coordonnées selon l'axe x
set bh [expr {$Longueur_Etran + [expr {$jh * $dist_entre_brise_H}]}];
set bv [expr {$Longueur_Etran + [expr {$jv * $dist_entre_brise_V}]}];
if {$bv == $bh} { set a $bh incr jh; incr jv; } else {
if { $bh < $bv} {
set a $bh;
incr jh;
} else {
set a $bv;
incr jv;
set c $Demi_Hauteur;
#Coordonnées selon l'axe y
for {set i 0} {$i<= $i_limit} {incr i} {
if {$Nbre_Brise_V != 0} {
switch -glob -- $i { 0 {set b -$Profondeur} 1 {set b [expr {-$Profondeur+$Brise_V_y}]} 2 {set b $Largeur_Etran_2} 3 {set b $Largeur_Etran_1} 4 {set b [expr {$Profondeur-$Brise_V_y}]} }
switch -glob -- $i { 0 {set d [expr {-$Profondeur+$Brise_V_y}]} 1 {set d $Largeur_Etran_2} 2 {set d $Largeur_Etran_1} 3 {set d [expr {$Profondeur-$Brise_V_y}]} 4 {set d $Profondeur} }
} else { set b0; set d 1;
} gg::conBegin
gg::segEnd
Old   July 3, 2007, 14:16
Default Re: scripting gridgen: why a connector is not save
Ben
I think this is best asked in the main forum as this is the STAR-CD one....
Old   July 28, 2007, 16:11
John Chawner
Tim,
The first thing that comes to mind is that the connector isn't saved because it duplicates one that already exists. Gridgen won't allow two connectors to be coincident.
I briefly looked at your script and didn't see any other obvious source of the problem. But I didn't run the script since it was just a fragment.
If this isn't the problem, contact Gridgen Tech Support at support@pointwise.com.
Gridgen- Connector redistribution function sea Pointwise & Gridgen 6 July 11, 2007 19:08
scripting in GridGen Tim Siemens 1 June 30, 2007 13:33
reading saved case and data maxime henno FLUENT 1 June 12, 2007 06:40
Gridgen - Link Database / Connector Nico Pointwise & Gridgen 1 April 21, 2007 13:59
very large saved files jelle Phoenics 4 August 5, 2005 08:49
