Home > Forums > CD-adapco
Autocad high quality STL file Autocad to CCM+
Old   July 31, 2007, 01:51
Default Autocad high quality STL file Autocad to CCM+
guillaume
Hi Could somebody expolain to me how to create a high quality STL file for CFD import. I runnning into all sorts of troubles with surfaces that have holes in them . Thanks a lot!
Old   July 31, 2007, 05:35
Default Re: Autocad high quality STL file Autocad to CCM+
Stephen
Sounds like your CAD model isn't great, or the export to STL faciity doesn't work.
If you have just a few holes, they can easily be repaired using STAR-CCM+'s manual repair tools. If there are many problems, try to use the surface wrapper.
Stephen
Old   July 31, 2007, 10:57
Jason
There is a plug-in for AutoCAD by Sycode that allows you to export more than one part in a STL file and also adjust the surface quality.
Old   August 9, 2007, 07:58
Kasper
there is a pARAmeter in acad called "facetres" that you can tune to get a better resolution of surfaces.
Thread Tools
Trackbacks are On
import an AUTOCAD file to Mentat leila Main CFD Forum 0 April 23, 2008 04:04
Autocad high quality STL file Autocad to CFD guillaume Main CFD Forum 1 July 31, 2007 05:48
how to export a 2-D autocad file to gambit? Ahmed Adel FLUENT 2 July 6, 2007 11:22
import autocad file ritmat FLUENT 5 June 1, 2007 12:19
Help!!!! Can gambit read the file from AutoCad? maoasis FLUENT 5 April 20, 2006 13:39
