August 1, 2007, 10:18 |
negative volume found in es-ice mesh
Hi all,
I have been working on a gasoline engine model with es-ice.The chamber has a spherical dome with valve seats extruding from the side where negative volume cells are found at some crank angles. When the result at a certain crank angle is created with the "interpolate" button on(no information about it in the tutorial), no negative volume is found and the mesh always has a good quality.However,this mesh still fails the test of starCD. Could anybody tell me how to generate (mapping method)a mesh with extruding valve seat and eliminate the negative volume cells?Or are there any button to turn on in es-ice or starcd and activate the interpolated results? Many thanks! |
August 4, 2007, 04:39 |
Re: negative volume found in es-ice mesh
I have only read the first paragraph, but that is sufficient. You are not the first engineer with this issue.
For specialist tools like this call adapco. |
Negative Volume in Mesh by Gridgen | James | FLUENT | 5 | February 3, 2010 07:34 |
Negative Volume Mesh | MANOJKUMAR | FLUENT | 8 | April 7, 2009 09:50 |
FSI & Negative Volume Mesh | Mojtaba | CFX | 1 | October 13, 2008 07:13 |
Negative volume in dynamic mesh | Max | FLUENT | 1 | August 7, 2006 05:18 |
Dynamic Mesh, negative volume! | ROOZBEH | FLUENT | 2 | June 22, 2006 20:51 |
