August 10, 2007, 03:57 |
WARNINGS I don't want to have
Hi there,
I wrote a macro and used it, after that in the output window the following message appeared. The first command is ok, becaus I would like to delet all in the graph registers and reset them. But my problem are the WARNINGS. Someone who know how I can repair that, that no WARNINGS appear? GRESET WILL RESET ALL GRAPHICAL PARAMETERS AND LOGICALS. DATA HAS BEEN STORED IN THE REGISTERS. THIS WILL BE LOST DO YOU WANT TO PROCEED? <Y/N> ALL GRAPHICAL VARIABLES AND LOGICALS RESET TO DEFAULT. ALL EXISTING REGISTER DATABASE HAVE BEEN CLEARD. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. **WARNING - MAY LOSE ACCURACY TRYING TO CONVERT INTEGER VALUES GREATER THAN 10000000 WHILE STORING SENSOR DATA INTO GRAPH REGISTERS. |
August 10, 2007, 08:07 |
Re: WARNINGS I don't want to have
Look at the SAFETY command.
August 10, 2007, 08:10 |
yea that way is the easiest, but not the best. What can I change in the memory commands for example to avoid these warnings. Do you know what I mean?
August 10, 2007, 17:04 |
It has nothing to do with the memory. The warnings are telling you that you can lose precision when converting integers into real numbers. The graph registers only deal with real numbers. If you want to turn off the warnings then turn them off.
Not to display warnings? | Yasser Nabavi | FLUENT | 3 | June 4, 2006 08:27 |
Warnings and problems with bc | evgenii | OpenFOAM Pre-Processing | 2 | February 7, 2006 07:44 |
WARNINGS | DB | Siemens | 0 | January 19, 2006 13:47 |
Warnings | Dave | Siemens | 2 | November 9, 2005 21:08 |
lots of warnings | Arnab | Siemens | 2 | January 27, 2005 15:36 |
