Error with posdat.f - undefined symbol: for_open
Old   August 16, 2007, 15:02
Default Error with posdat.f - undefined symbol: for_open
Emmanuel Resch
I encounter the following error when executing star. Just when posdat.f is called, the following message appears in the STAR window:
... "undefined symbol: for_open"
I get this error because in my code I'm trying to use inherent Fortran functions, such as OPEN, CLOSE, WRITE. Apparently, some inherent Fortran functions, including i/o functions, require linking additional Intel libraries to the STAR-CD user-supplied dynamic library libstarusr.so. I have found out what these libraries are and where they are located on my system, but I have no idea how to link them to libstarusr.so.
The following webpage describes my problem almost perfectly, but the solution they offer goes right over my head... http://www.adina.com/faq/qg008.shtml
Any help on how to fix libstarusr.so so that I can use these Fortran functions?
Thanks so much.
Old   August 16, 2007, 15:42
Default Re: Error with posdat.f - undefined symbol: for_op
Richard
You could try the -ulib option of star to link in the library manually. The Fortran libraries which star links in by default are under $RUNTIME. It may be that CD-adapco can supply you with more recent $RUNTIME, compatible with your Fortran compiler, which will prevent you having to do anything manually.
Old   August 20, 2007, 15:46
Emmanuel Resch
Thank you Richard. Your suggestion for using the command: star -ulib worked. what i needed to do was find the intel fortran librairies on my computer that had the symbol "for_open". I did that by pathing to the /opt/intel/fc/"version"/lib directory and searching within the librairies for the symbol: "for_open"
This gave the following:
[user@redhat4 lib]$grep "for_open" *
Binary file libifcore.a matches
Binary file libifcoremt.a matches
Binary file libifcoremt_pic.a matches
Binary file libifcoremt.so.5 matches
Binary file libifcore_pic.a matches
Binary file libifcore.so.5 matches
I then copied "libifcoremt.so.5" and "libifcore.so.5" to the dynamic shared object folder in the star problem directory: .../ufile/linux_2.4-ifc_7.0-glibc_2.2.2-dso
Finally, I ran the following command, (where $LIB=ufile/linux_2.4-ifc_7.0-glibc_2.2.2-dso):
star -ulib="$LIB/libstarusr.so $LIB/libifcoremt.so.5 $LIB/libifcore.so.5"
This fixed the problem. Hope this helps anyone who has been running into this problem of "undefined symbol". It most likely has to do with using a newer version of the Fortran compiler and STAR is using librairies with different names that correspond to Intel FC 7.0...
libudf error: undefined symbol: Prashanth FLUENT 6 August 22, 2019 00:24
OpenFOAM 15 libreadlineso5 undefined symbol PC frafridr OpenFOAM Installation 0 February 3, 2009 19:37
Symbol lookup error in 14 that was not present in 13 adona058 OpenFOAM Bugs 1 July 25, 2007 16:04
undefined symbol Dario Nexus FLUENT 0 October 12, 2006 07:54
[OpenFOAM] Paraview symbol lookup error dewald ParaView 3 December 14, 2005 02:36
