August 14, 2007, 20:44 |
SIGABRT
I have problems with SIGABRT because when run the simulation on the screen appears the following error: PNP: Received PNP: Initialized [2007-08-15-02:29:11] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "xxxx,1" resource (1 process). PNP: Assigned "xxxx,1" to STAR solver (1 process). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Spawning STAR process on single node. PNP: Shutdown [2007-08-15-02:34:22] Execution aborted by request (SIGABRT) after 311 seconds (TOTAL ELAPSED TIME). I used the Run Solver by STAR-Launch. When I used STAR CCM+ this error doesn't occur altough the xxx.ccm were the same. What's happen? Thanks for your help
August 15, 2007, 09:26 |
Re: SIGABRT
I not anderstand, why it message "Parallel analyzer" and then message "Allocated "xxxx,1" resource (1 process). PNP: Assigned "xxxx,1" to STAR solver (1 process)". May be you use parallel single host? But i think you need sequintal? Or i wrong?
August 16, 2007, 06:45 |
Re: SIGABRT
I installed mks server withouth of it prostar doesn't launch. Can be a configuration problem? When I launch the prostar with OpenGL control on the prostar-launch the display answer: XL lib error openGL... how if doesn't find a video card file. Do you know the procedure to config MKS server with my ATI video card, and then what's the functionality of MKS server? And MPICH? Thanks
August 16, 2007, 11:54 |
Re: SIGABRT
What operating system are you using?
Have you tried the xm option instead of the open GL? I use xm for both Red Hat LINUX and XP Pro. One unit has an ATI and the other has nvida video cards. MPICH is a message passing linrary used for parallel calculations. Tom |
August 20, 2007, 12:21 |
Re: SIGABRT
Chris I'm guessing your running in windows, can you confirm that your xserver is setup and running correctly?
September 6, 2007, 12:07 |
Re: SIGABRT
Yes, I have a 3.26 version of star cd and the simulations is ok because makes numerical solutions. I launch MKS Server and all function (I thought a server problem; can be a microsoft problem? Which? I read Client Microsoft problem,Star Watch problem, directory problem?) Help me!!
September 6, 2007, 12:15 |
Re: SIGABRT
I use XP MCE the next version of XP Pro, but I don't think it's graphics problem because the MKS Server functions well. Can be a compatibility problem between 3.26 and 4.02 problem as having the same directory?
Display Modes | |
SIGABRT error | Filippo | Siemens | 7 | February 28, 2008 04:14 |
