STAR-CD v4.02 parallel problems on Win XP 64 bit
Old   September 18, 2007, 09:09
Default STAR-CD v4.02 parallel problems on Win XP 64 bit
Kasper
The subject pretty much covers my problem.
When I'am trying to run a case the solver crashes at the decomposition of the mesh. The error is something like: "star402.exe generated an error and must be closed" - it is a kind of standard xp error I think.
So how do I solve this problem? Does anyone experience similar problems?
More info:
I have 1.850.000 cells it is steady state and geom(CCM) file is writen without any problems.
I have a region with porous media and some solid and porous baffles.
My PC is a quad core xeon 3GHz with 8 GB ram. Trying to use to processors.
Best Regards, Kasper
Old   September 19, 2007, 08:42
Default Re: STAR-CD v4.02 parallel problems on Win XP 64 b
redrabbit
maybe try something like
star -decompose 4
from the windows shell and see what you get.
if this works then try
star -nodecomp 4
What do you get? Otherwise Support is a good place for help in answering your question.
Old   September 19, 2007, 08:46
Kasper
Thank you,
Support has been working on this for a while now. sadly...
Old   September 24, 2007, 06:06
Kasper
*Here is the solution:
Install Star-CD's version 4.0 which comes in 64 bit now.
Parallel works and everything is fine now.
Thay have recently released the 64 bit version (mid september)..
Regards Kasper, Denmark
Parallel Run Problems Jason Siemens 1 November 24, 2008 12:32
Problems with parallel wolfgray OpenFOAM Running, Solving & CFD 0 April 14, 2008 04:36
PVM parallel problems stex_CFD CFX 3 June 29, 2005 09:16
CFX - Parallel Problems CFX User CFX 0 November 1, 2004 18:12
parallel Star-CD Andy Siemens 1 December 6, 2002 10:11
