Duct Flow Analysis
Old   September 26, 2007, 11:40
Default Duct Flow Analysis
benbru
I have imported a CAD model of a duct that I designed into ProAM. My problem is ProAM is treating the imported CAD as the working fluid. I can't seem to figure out how to actually make my volume mesh the volume inside the duct instead of the duct geometry itself.
I went through the tutorials and they all use a CAD model of a fluid instead of the case that I described above. I also used ProSurf to import the original geometry.
Can somebody explain to me how to make my volume mesh the volume inside the duct? Thanks to anybody who replies!
Old   September 26, 2007, 15:53
Default Re: Duct Flow Analysis
Pauli
Extract the inner surfaces.
Use the hfil command to close the ends.
Run the corient command to get all the shell normals pointing the same direction.
Depending upon the geometry, you'll probably want to add line cells (live edge).
Tutorials & demos have little to do with the real world!
Duct flow Omar Mohamud FLUENT 1 February 23, 2020 21:33
flow through duct N. Natik FLUENT 3 January 9, 2006 08:15
Duct Flow Ahmed FLUENT 3 July 23, 2002 19:47
Duct Flow omar Main CFD Forum 4 December 9, 1999 12:43
Duct Flow Sanjay Padhiar Main CFD Forum 0 February 24, 1999 09:02
