Home > Forums > CD-adapco
Sector model mesh problems!!
Old   October 5, 2007, 06:57
Default Sector model mesh problems!!
Duan J Q
Hello, everybody, who has experience work with sector mesh? Who can tell me what is going on? When I check for illegal and bad cells, there will appears "error #74: There are cracks (unconnected regions) in the model" But if I merge the vertices, the message will disappear, the error messages "Error*** side 1 of cell 330 connects to 334 whitch is a boundary/cut Error ***side 2 of cell 56464 connects to 876464 which connects back to 455646" will appear when move events after execute STAR.
Old   October 5, 2007, 12:37
Default Re: Sector model mesh problems!!
Pauli
It's hard to say without seeing your grid.
How are your creating your mesh? Are you using es-ice, Prostar, or some other code? Is this a trim mesh?
Are you starting with a shell mesh & extruding it into a sector? If so, you should not have cracks.
Do you have embedded refinement (couples)?
Old   October 6, 2007, 20:09
Duan J Q
Dear Pauli: I used es-ice when I created mesh. And I used trim method. The mesh is created in es-ice automatically. As you say, if I created mesh starting with a shell mesh & extruding it into a sector, Must needs write events manually?
Old   October 7, 2007, 11:31
Pauli
Yes you would have to manually build the events & cgrid files.
For a sector mesh (no moving valves) it is not that bad. I started with the tutorial & made it work. It took a few days to get it working and another couple to fine tune matters.
Back to your problem, I have no experience with es-ice & trimmed mesh. The error messages hint at a trim cell issue. If I were in your position, I'd forward the problem to support.
Old   October 7, 2007, 20:05
Duan J Q
thank you
Thread Tools
Trackbacks are On
es-ice sector mesh Luke from Australia CD-adapco 0 September 28, 2008 00:35
Problems when I mesh my engine model. deisler CD-adapco 3 March 22, 2007 22:58
KIVA sector mesh with valves Tomislav Main CFD Forum 0 December 12, 2005 06:39
crack in sector mesh escapist CD-adapco 2 May 19, 2005 07:25
Model and Mesh generation Problems Anindya Main CFD Forum 1 May 19, 2001 02:02
