setting limits
Old   October 9, 2007, 06:22
Default setting limits
Mac
Hi....is there any way of setting limits in STARCD (be it velocity, pressure, turbulence, etc), as in solution limits?? In this way you are imposing the limits on the computation, and should the computed values increase beyond this...the iteration is terminated by the solver. Can these limits be set in the solver?? Thanks in advance.
Old   October 9, 2007, 08:00
Default Re: setting limits
Anton Lyaskin
Yes, it is possible to do with real constants, at least from the lower side (you should contact CD-Adapco to find out which one for what). But iterations will not be terminated by the solver, it will just set the variable to the limiter value
Old   October 9, 2007, 08:07
Mac
Thanks for the reply. How do I set the limiter value in the real constant? Can you help me with this. Thanks.
Old   October 10, 2007, 05:51
Anton Lyaskin
Just use RCONST <constant number> <value> or go to Analysis Controls->Other Controls->Switches and Real Constants panel, then choose Real Constants tab
Old   October 10, 2007, 06:37
Mac
I wanted to know the real constant number that should be activated for setting the limits. Do you have the real constant value ?? Thanks - Mac.
Old   October 11, 2007, 07:13
Anton Lyaskin
For real constant numbers you should ask CD-Adpaco. As far as I remember, something was also mentioned at this foru.
solution limits seeyou FLUENT 0 July 21, 2007 23:27
Setting Solution Limits S K Prasad Main CFD Forum 0 January 3, 2006 04:45
Setting Solution Limits S K Prasad FLUENT 0 January 3, 2006 03:18
Solution limits pp FLUENT 1 June 28, 2004 12:53
Limits on the number of BC Tim P. FLUENT 0 June 14, 2004 15:15
