External Aerodynamic Meshing
Old   October 26, 2007, 19:25
Default External Aerodynamic Meshing
benbru
I opened a surface mesh of an airfoil (created in pro-surf) in ProAM. I created a box around the airfoil to serve as the exterior of fluid domain.
I thought that when I made my volume mesh it would mesh between the two surfaces, but that was not the case. It meshed the inside of the airfoil and seems to simply have deleted the box.
Is there a setting I have to change to switch the side of the airfoil that gets the mesh? I looked at the ProAM users guide, but it just mentioned that if you are doing external aero you have to create the box. Thanks to anybody who responds!
Old   October 27, 2007, 03:50
Default Re: External Aerodynamic Meshing
reza
You might want to check if your box has a surface mesh already. If not, ProAM will not recognize as part of your domain. Try checking it with Surface Tool --> Check Surface on the main ProAM window.
My second idea is to make the box directly inside ProAM. ProAM is also capable in making such box for external aero cases. Look for this also in the main window.
Old   October 29, 2007, 02:28
ravi
u can also try the "orient surface" feature in PRO-AM b4 generating the subsurface for the mesh-creation.then chk if the subsurface is created between the airfoil and the box surface.
best of luck.
Old   October 29, 2007, 02:33
ravi
1 sec , how r u generating a volume mesh for an airfoil.!!!!!!!!!!!!!
Old   October 29, 2007, 13:50
benbru
Hi ravi, I think that the shell orientation is probably my problem. I did make the external box and it did have a surface grid on it so it must be the shell orientation. I'll try it and let you know how it turns out.
Ravi, to answer your question. After I made the box and then made the volume mesh pro-am just seemed to delete the box and it meshed the inside of the airfoil (I'm still not sure why it deleted the box). It was treating the airfoil itself as the fluid.
I had a similar problem to this before. I was doing flow in a duct. I had to simply extract the inside surface of my cad model and then close the ends, but the external aero is a little bit of a different beast.
Old   October 30, 2007, 00:13
ravi
http://www.cfd-online.com/Forum/starcd.cgi?read=13089
go to this link.
and my Qs was not wat u perceived, but i told , airfoil is a 2D geom, it has to be a wing to create the volume mesh.
Old   October 30, 2007, 01:31
ding
http://www.cfd-online.com/Forum/star...cgi?read=12689
Old   November 26, 2007, 20:04
Airfoil
Have you export your airfoil surface as mesh from Pro-surf to Pro-AM? In order to generate volume mesh from Pro-Am, you must have surface mesh. Remember to create edges and point for your geometry too.
Old   December 5, 2007, 00:13
ding
ya, u need to generate the surface mesh in pro-surf b4 importing the .dbs file in Pro-am.
External Aerodynamic Simulation+negative densities Ramkumar Siemens 2 February 19, 2008 04:18
external aerodynamic Mattia Main CFD Forum 1 July 20, 2007 16:53
Pro*AM meshing of external flows Cb Siemens 2 February 18, 2005 06:31
External Aerodynamic - CFD Vs WT tests Daniel Main CFD Forum 1 January 13, 2003 19:54
External flow aerodynamic Sulaiman akhlaken Siemens 0 September 5, 2002 02:54
