Home > Forums > CD-adapco
parallel processing V 3.24
Old   November 9, 2007, 04:53
Default parallel processing V 3.24
Phil D
I have a model using ASIs and want to run it on 10 processors simultaniously. So I have to ensure that all ASIs are on one set. So far it's right, isn't it?
But do I create those decomposition and what do I have to consider when I start the solver? Any help? Sorry couldn't find any detailed description in the forum.
Thanks,
Phil
Old   November 9, 2007, 05:36
Default Re: parallel processing V 3.24
Jörn Beilke
You have to create a set-file with a manual decomposition.
You should consider, that the updating the sliding interface sometimes takes as much time as solving for the flow field. So the possible maximum speedup for this configuration would be 2 which ist not that much.
Old   November 9, 2007, 07:50
Phil D
Thanks!
Well, I think I can create those file with the "writesets" command?! But those files are decomposed automatically when I start the solver or is there any other command I have to include (like "decompmeth")?
In other applications I started the solver using STARLAUNCH but in the present case thats not possible.
Thanks in advance,
Phil
Old   November 10, 2007, 05:31
olga
For the solverrun use option '-decompmeth=s'for decomposition according to your setfile.
Thread Tools
Trackbacks are On
Parallel Processing pipe FLUENT 0 December 22, 2008 11:34
FSI and parallel processing Jorn CFX 5 June 8, 2007 15:53
Parallel processing and FSI guus_kupers OpenFOAM Running, Solving & CFD 0 March 20, 2007 10:40
Parallel Processing Drew Abbott FLUENT 2 August 29, 2006 12:35
Parallel processing Phil FLUENT 1 May 27, 2004 07:18
