extract point data
Old   November 26, 2007, 09:26
Default extract point data
susan
I wanna extract one-point data after solving
Though I can see particle trace, can't extract data
What I want is only extracting one-point transient data to use at techplot, not whole data
Old   November 26, 2007, 13:34
Default Re: extract point data
BastiL
You mean you want to set one point using x-y-z coordinates and extract postprocessing values of this point? IS the point connected to the mesh?
Old   November 26, 2007, 19:49
susan
um...
for example,,,
I concerned about fan motion. so I focus on one-spot, which is on the blade.
Rotation fan, one-spot will move.
Then I extract an information about one-spot,,changing velocity, pressure fluctuation, temperature,,,etc.
How to get to extract these information...
Old   November 27, 2007, 02:43
BastiL
Susan,
do you have a vertax at this position that is connected to you mesh? In that case you can simply write out post-data.
Oterwise set a vertex in the interesting position and interpolate data on it. Afterwards you can also write it out.
Regards
Old   November 27, 2007, 14:04
fan modeller
you can do this in star-ccm+ using a derived part(point). The point will not move location while the mesh will rotate or translate using rigid body motion.
it is better to use star-ccm+ than star-cd for this type of application.
the best way to extract data from a figure Feitoudaer Main CFD Forum 19 April 8, 2021 01:28
extract bibtex data from pdf/ps files?? pdf-bibtex Main CFD Forum 11 January 20, 2010 11:26
Data Extract -- Time & Location selim FLUENT 0 March 27, 2008 03:41
extract data into external file DW FLUENT 0 June 3, 2005 12:36
how extract data from plot3d file yangqing FLUENT 0 January 27, 2002 10:20
