debugger with STAR CD V4
Hi
Can anyone help me out in how to use the debugger while running the case having the user subroutines. Basically, I want to implement check bounds etc. Is there also any info regarding how to set the flags of 'no optimization', flush denormalize,'floating point exceptions' etc. while running the star with subroutines. Thanks |
Re: debugger with STAR CD V4
The best way is to add print statements. If you need a debugger it means you are writing a long code. In this situation, write and debug the code you are writing on the side, there after plug it to star-cd via a call statement within one of the subroutine. This is the correct practice.
