December 3, 2007, 10:53 |
Compressible flow analysis
I am new to STARCD. I am working on the Exhaust pipe and compressble flow. I know what should be done in incompressible flow analysis. what are the extra things I need to do for Compressible flow analysis. Thanks a lot in advance
December 4, 2007, 13:36 |
Re: Compressible flow analysis
Change the fluid density to ideal gas, and you will also need to specify the molecular weight of the gas (28.96 kg/kmol for air).
I assume that the Mach number is fairly low (< 0.3), so you really shouldn't have any convergence problems. |
December 5, 2007, 01:19 |
I am also having a similar problem related to the compressibility. when i run the simulation for an engine intake(Mach = 0.7), it gives an error msg, "negative densities found at more than 1000 locations." I am using ideal(T,P) in the Mol. properties and high reynolds k-e turb model. can sm1 help me , wat extra condition i need to apply to get the results.
,thanks |
December 5, 2007, 08:25 |
This can be due to either the temperature or the absolute pressure going negative. In your case, since M=0.7, negative absolute pressures are probably temporarily occing during the solution.
Is your analysis steady-state or transient? If steady, try ramping up the inlet velocity (or pressure) over the first few hundred iterations. This can be done using a very simple user subroutine. More advice can be found at: http://www.adapco-online.com/adapco_...ompr-flow.html |
Display Modes | |
Internal Flow BCs for Compressible inlet flow | Katie | FLUENT | 2 | March 3, 2012 18:35 |
Mass flow inlet compressible flow | richard | FLUENT | 2 | June 1, 2008 12:44 |
compressible flow | Paco | Main CFD Forum | 1 | April 20, 2004 05:18 |
convert compressible flow into incompressible flow | Hun Jung | Main CFD Forum | 4 | August 11, 2003 11:10 |
External Flow-compressible flow solver-lift/drag | Tom Brown | Main CFD Forum | 7 | December 29, 2000 14:41 |
