Axisymmetric extrusion
Old   December 13, 2007, 12:08
Default Axisymmetric extrusion
Corentin
Hi!
I have a 2d profile in the XY plan and I would like to have it extruded in axisymmetry, with Y being the radius.
I know the 2d3d function can do it, but it does it with the X direction for the radius, how can I change it?
Thanks!
Old   December 13, 2007, 15:52
Default Re: Axisymmetric extrusion
Pauli
My guess - Perform the operation with CSYS set to a properly aligned cylindrical coordinate system?
Old   December 13, 2007, 15:58
Corentin
Thank you, but I tried.
After creating the geometry, I created a new coordinate system, performing some rotation, and I activated this new coordinate system.
Then I used the 2d3d function.
It did exactly the same as before, just as if the old coordinate system was still active.
It seems that the 2d3d function didn't operate in the new coordinate system.
I am so desperate...
Old   December 13, 2007, 16:20
James
type help vcex, one of the options is which system you want to use
Old   December 14, 2007, 11:53
Pauli
You should take James' advice.
I never use the 2d3d functions. I do all my extrusions using vcex. I'm pretty sure at some point I've done axi-symmetric extrusion with vcex. The trick is to use a cylindrical coordinate system.
Axisymmetric Modelling using 2D extrusion Steve CFX 0 November 12, 2008 12:05
What is the extrusion layer Radhika Siemens 5 February 2, 2007 17:06
mesh extrusion giri Siemens 2 November 13, 2006 05:02
Axisymmetric Mesh extrusion (2d-3d cylinder) ben akih CFX 0 August 21, 2006 19:03
extrusion Sabatini Siemens 2 May 20, 2003 15:57
